I'm currently doing some renovation in the bedroom, it requires removing the rad for a period of time while the work is done.
I've had some x400 sludge remover in the CH system for a few months so today I drained down the system (flushing it out by opening the fill valve and letting it drain outside via a hose). Water was very very black.
I then removed the rad and capped off the supply pipes to it with stop ends. Topped the pressure backed up on the Alpha 28C boiler fine.
Few hours later though we notice both the hot and cold water have very little pressure when you open a tap. The boiler pressure gauge is fine but when I open the filling loop, the pressure doesn't rise as it normally does and it feels a bit stiff. I've checked round for leaks and found none.
Any ideas what I've done to cause the problem?
