Loud bang when cistern filling
17 Sep 2025
We have recently had two bathrooms renovated. When we flush the toilet in both bathrooms we hear a loud bang when the cistern has finished filling. The thud can also be heard from the airing cupboard.
We also hear what sounds like a pipe rattling loudly as the cistern starts to fill in the main bathroom.
Both bathrooms have ALCA concealed cisterns with an A160P cistern/fill valve which is down as "smooth closing" in the features list.
We have a pressurised system with a pressure reducing valve and have no issues or noises when using any taps/showers or baths.
Any idea what could resolve this issue?
Thanks for any help.
Water hammer.
Fit water hammer arrestor on toilet.
You can try turning stop tap back a bit and see what happens
Often caused by a high mains pressure, and too quick a flow, filling the cistern rapidly. You could try reducing the speed of the fill, either by adding an isolating valve in the supply pipe to each, and not turning it on fully, or...
You can fit a disc, with a small hole in, where the pipe connects to the fill valve - these are often used to slow the flow into a washing machine.
Thank you both for your responses.
Is this stuff that can be accessed through the flush plate? The bathrooms are complete with the in wall toilet frames tiled in.
Test the limiting the flow first, by turning your stop tap down, and flushing - see if you still hear the thumps.
Thanks Harry
Attempted both turning the stop tap down and reducing the flow fill valve behind the flush plate.
No change until the fill valve was practically closed which then created a loud long rumble until it closed.
Yes, but they didn't seem to know a fix other than fitting a hammer arrestor, which considering the pipes are behind a tiled wall wasn't practical.
Happy to say that I have found the solution.
I replaced the ALCA A106P filling valve with a Fluidmaster 747EL (due to 3/8" fitting) and the problem has completely gone.
No water hammer when filling starts or stops.
Thanks for everyones replies.
