EDIT: I've renamed this from the original title of 'Ferroli Optima 701 Hot water pressure' In case this is a problem unrelated to the boiler model.
Good evening Ladies and Gents, many apologies if this has been answered elsewhere but I've read the wiki and done a search and still am no closer to finding an answer. I'm no plumber (as i assume are many of your first time posters) but would greatly appreciate the opinion of someone who might help.
We moved into our house a few years ago and the hot water pressure from taps has never been particularly great which has never been an issue as we rarely take baths as we use the shower (where the pressure has appeared fine). The boiler which was already fitted in the house is Ferroli and a sticker inside the front flap says Optima 701 (and indeed it does look like the one here : http://www.aroundtownflats.com/manuals/Boilers/Ferroli/FERROLI OPTIMA 701 GCNo.47-267-16.pdf).
Hot sink taps have always been usable but not certainly strong but hot bath hot tap has always been pretty weak. Cold taps all fine.
However, shortly before Christmas we noticed the water in the shower being particularly cool. After a bit of experimenting we've found that if we use the shower on low water pressure the temp is fine but obviously the flow is low. If we try it on normal flow the hot water is 'drowned out' by the cold water.
Since noticing the shower seems to have lost hot water pressure, all taps remain unchanged. Radiators appear to work fine and need no bleeding.
Boiler pressure is 1bar when cold, rising to about 2.7 when with central heating turned on. Boiler temp set to about 70c, mode is set to 'Heating
continuous and hot water'. I've never had a problem with the boiler itself losing pressure apart from some over-enthusiastic radiator bleeding a few years back which needed a water topup as the pilot went out.
Any ideas what might be causing the low pressure in the shower etc? It seems to be heating the water fine.
