Low hot water flow
2 Apr 2018
Have a logic 24 combi boiler and just had to re pressurise the boiler but now the hot water flow is very poor any ideas what the problem is
Is the hot water flow poor on every tap in the property ? Is cold water pressure at your kitchen tap good as normal ? Topping up boiler pressure should have no direct effect on your domestic hot water outlets.
Did you accidentally turn the cold water isolation valve while re-filling the combi,The cold water isolation valve needs to be 100% on/open.
Must be some video on yootube :cautious:
Cold water pressure is not affected and yes, the flow is poor on every hot tap?? Have tried YouTube but only seem to get how to re pressurise the boiler itself, can't find anything re poor flow afterwards??
Did you check out old & colds suggestion re the boilers cold inlet valve ?
Will get OH to check re cold inlet valve thanks for the suggestions
