Low Hot Water Pressure from Unvented System
27 Apr 2012
Cambridgeshire
We have started to suffer from low hot water pressure from an unvented system.
Having ensured that there is an air gap in the main hot water tank the problem goes away for a short while but then returns. I presume the air gap is not being retained in the hot tank.
Can anybody suggest how I can fix this.
It seems the flow rate into your cylinder is restricted.
Have you had it serviced regularly?
Work on unventeds should only be done by apppropriately qualified people.
Tony
