Hi
Something that has literally deveoped overnight. Ultrasteel unvented cylinder set up.
Direct hot feed (literally 1metre) to bar shower mixer has low pressure when turning temp to wamer settings.
Took bar mixer off and turned back on water supply - cold shoots across the cubicle but hot dribbles out of the elbow.
No leaks internally and all other taps in 3 story town house working fine hot or cold.
Hot water for shower is teed off from hot going to upstairs bathroom where hot pressure is fine, only a double check valve after the T, is this the issue?. How easy is it to replace if so?
thanks
Sunil
thanks
Sunil
