I am installing a wetroom in our en-suite bathroom and I have replaced the old aqualisa shower with a 0.1 Bar thermostatic mixer valve (22 mm connections, Hot in, Cold in and mixed out). It is feeding a 0.1 Bar low pressure 'drench'shower head.
The old shower was plumbed with 15mm piping so I have retained these runs of pipe and just used reducers to connect to the mixer valve within 8 inches of the valve.
The cold feed comes direct from the loft water tank with an 8 foot length of 15mm pipe that then drops down through the ceiling into the shower cubicle.It has a couple of 90 degree bends before connecting to the mixer valve. There is an old Gate Valve (with red knob) where the 15mm pipe just comes out of the loft water storage tank. There is a 4 foot head of water from the bottom of this tank to the shower head.
The 15mm hot feed comes under the floor via the 22mm pipe that feeds the bath but reducers to 15mm about 6 feet before it reaches the mixer valve. There are 4 X 90 degree bends in this pipe.
Both the hot and cold water pressures are poor. The cold is worse than the hot. If I turn the mixer valve to fully cold the water dribbles out of the shower head. When the valve is turned to hot, the pressure is just about acceptable but poor. In the mixer valve mid point, the pressure is about the same as when set to hot.
If I remove the shower head and monitor the water flow directly out of the wall plate elbow, it is pretty poor, ie. water projects about 1.5 to 2 inches from the pipe.
The hot water pressure has never been brilliant at any of the hot taps in the house except for the bath. The main bathroom shower is plumbed completely with 22mm piping and uses the exactly the same mixer valve as I am using in the en-suite, although it uses a different 0.1 Bar shower rose, and it also suffered with the same low water pressure problem. I fitted a pump to solve this shower pressure problem. I really don't want to fit another pump for the en-suite. I feel that with 4 foot of water head, I ought to be getting enough pressure.
Before I progress any further I thought I would post this problem to see if anyone has any suggestions.
I am suspicious of the gate valve in the cold feed, possible blockages in the 15mm feed, debris in the mixer valve.
Any suggestions welcome at this stage.
Regards
Regards
