hi i have very low pressure in my kitchen hot water top just dribbles out but cold fine loads of pressure. is there anything i could do to increase pressure.
thanks in advance
thanks in advance
give us some more info on the system that supplies the hot water to the taps.
is it gravity fed, mains fed ?
is it the only tap thats a problem ?
was the water turned off when you moved in? it may be just an airlock
is it a mixer or single taps in kitchen
maybe a high pressure tap fitted to low pressure system.
maybe isolation valve not fully open.
how do i know if its high or a low pressure top its a mixer
