- Joined
- 20 Sep 2015
- Messages
- 79
- Reaction score
- 1
- Country
Hello. I have a 4 year old Vaillant combi boiler, serviced annually (last service July 2025). 4 bed dormer with 2 en suite showers and a separate bathroom shower, all off the mains water. There is only my wife and I living at the property. We had a guest, using the other en suite shower, from July to September, but he has now moved to his new home. Since around beginning of October, the hot water pressure in the main bedroom (downstairs) en suite shower has been slowly reducing. It comes out of the overhead fixed shower head very slowly when turned on and the flow increases after about 2 minutes to something that can be used, i.e. more than a trickle and hot (ish). I have bled all of the rads and also turned the stop valve off, (with the boiler off) and opened all of the water outlets, then turned the main stop valve back on and closed all of the taps, one at a time after any spluttering ended, where applicable. Neither of these actions, taken separately, made any difference. The hot water pressure out of other taps around the house is a little lower but not as noticeably as the main en suite fixed shower head. I also took the fixed shower head off to give it a thorough clean in case there was any limescale build up in the shower head nozzles. No difference. The main en suite shower also has a hand held shower head, which is, of course, on the same pipework as the fixed head. The pressure out of this also seems reduced. The cold water does not seem affected. I also increased the water pressure in the boiler to 1.8 bar from 1.5, but this has made no difference either. Your professional advice/suggestions to the basic cause and the remedy would be greatly appreciated.
