Just fitted two ten bulb low voltage ceiling lights with 20w Halogen bulbs.
One normal switch and one dimmer switch.
Old fittings had 5 40w bulbs each so wattage and dimmer should be ok
When switching on, all bulbs are ok, then a few seconds they dim, flicker and a humming noise is heard from both fittings - it's driving us nuts.
One fitting has a loose arm where the earth is connected - possible cause
These DAR lights look great, but when fitted one bulb on one fitting didn't work, live wire not fitted in connector in factory and other fitting has the loose arms as previously mentioned - German/Chinese quality control sucks
Any advice greatfully received.
Thanks guys.
Thanks guys.
