Hi - I am hoping to install/have installed low voltage lighting under my kitchen units:
The kit I am thinking about comes with transformer and 3 lights (with 1 metre of cable each).
- 1 metre of cable is not enough - is it ok to extend the cables (by cutting them and inserting a longer length in the middle)?
- The transformer comes with a 3 pin plug - is it normal to run such lights off the ring main instead of the lighting circuit?
- To add a light switch is it a case of cut the cable between the plug and transformer and wire in a switch?
