Luke Warm Water only & F.71 Code
21 Sep 2009
Just wondering if anyone can shed any light on my problem.
It only just started doing it this morning, I have luke warm water and fault code f.71 on my boiler, any ideas?
Checked the book and it reads:Flow NTC reports constant value [stuck at] and it says the cause:Flow NTC is defective?
I would check the flow ntc is attached correctly to the pipe work and also test it's resistance.
Failing that I would replace it to eliminate it.
