Hi Folks.
I need some help! I've looked around these boards and there's nothing that matches my problem.
We had a conservatory added in the summer which included a new radiator. Until now we've never even switched it on. Now we've tried it doesn't get anywhere near hot enough to warm the room.
The radiator was tapped into the existing system and is now the furthest rad from the boiler. The one next to it is working perfectly. The inlet pipe to the new rad is normally hot. The top of the rad is normally quite cold but with the system being on 18hrs/day over the holiday it is now quite warm. The bottom is stone cold. The outlet pipe is cold also. There is no airlock. We had other problems with the system in the Autumn which resulted in a new pump and thermo being installed.
The rad has a Optima valve with settings 1-5. I've tried settings 1 and 5 but it makes no difference. When grabbing the whole valve I'm able to twist it and it can click into 3 different positions. I haven't got a clue what this does.
Any ideas?
Cheers
Adrian
Any ideas?
Cheers
Adrian
