Just wondering if anyone can give me some advice?
I'm having to install a toilet macerator (I realise the opinions and have come to accept that these are the work of the devil, but in this case a necessary evil)
My question is quite simple... Essentially the main drainage pipe is totally inaccessible.
Coming from the macerator is 22mm pipe which is solvent welded. This runs for about 2m. It then becomes a 40mm pipe and slopes off into the main stack about another 3 m away. Unfortunately the main stack is totally inaccessible (beneath a glued down hardwood floor) and the 40mm piece of pipe joins through a 90 degree pushfit joint.
I understand that ideally I should only use solvent welded joints... But given the access problems, I wonder if because the diameter of the pipe is increasing from 22mm to 40mm it might be okay in this instance as there shouldn't be much pressure at that final joint?
Any advice or thoughts would be appreciated!!
