I'm knicking that idea with the boxing in. Looks greatI’m happy with the Sanislim macerator in our downstairs loo. Basin is plumbed in to it too and you can even add a shower to it if you wanted. I boxed ours in and added some sound deadening so it’s a lot quieter than any other macerator I've ever heard.
Just make it all easy to remove.I'm knicking that idea with the boxing in. Looks great
Thanks for the link.https://www.plumbworld.co.uk/grundfos-sololift2-wc1-97775329-19701-25528 this says it has a self clean design
Somewhat surprised to read you coudnt buy an nrv for a Turbo unless you were trying local plumbers merchants. Saniflo spares are generally available for a considerable time after production of a model comes to an end and that doesnt happen often.Before you buy, check to see if you can get spares for the model your looking at.
Like a non return valve - they seem to be a common failure.
Else when installing ensure you have the piping so you can install an external valve, also a drain point in the outlet pipe so it can be drained off iff the macerator gets glogged up because er indoors etc. used wet wipes a lot.
Ditto the turboflush, I have one and cannot get a replacement valve so fitted an external one.
