hi everybody.
cant get the hot water working on this model[the pin will not move out to hit the micro switch].i have stripped the boiler cleaned all waterways of limescale,replaced full diverter valve including hot water valve.checked the small copper tubes are not blocked.i have checked and cleaned the flow cartridge.dhw plate heat exchanger is not blocked.cold water flow and pressure are fine.boiler fires for central heating and fires up if i press the dhw micro switch.
