mains downlighters
30 Jun 2005
could anybody tell me if there is a limit to how many downlighters you could have in any particular area in a room ie. how close can they be?
How close do you want them, how many and what wattage are they. What other lights are on the current cicuit?
Are you trying to illuminate the area or heat it :p
hi nstreet. firstly in answer to your query they are to provide lighting only and not to heat up a particular area.
the lights in quetion are 50w mains and there will be five of them in a "cross" formation with about 8 - 10 inches spacing between them.
The only other lights on the circuit are two 60w pendant lights.
i suppose what i really want to know is that will there be any significant heat build up caused by the lights possibly being too close
Thats will be quite a lot of light in a small area:cool: . Are your measurements between fittings or the centres of the fittings. If its between centres then they are very close together.
Most downlights will have some sort of indication of spacing in the spec. There will normally be minimum distance from the outside of the fitting to another object. In the case of my fittings it was 50mm. You could always phone the manufacturer or supplier, they should be able to answer your question.
Also are they in the loft space or between floors? If its between floors I suspect the heat could be a problem.
Loads of stuff on this site about no. of lights on circuit.
P=IV
Lighting circuit I = 5A
V = 240v
So max P would be 5 x 240 = 1200watts
All you're putting on one circuit is 5 spots @ 50w a piece, plus two 60w pendants, which is only 370w in total.
I'm no pro electrician but it sounds fine by me.
For heating issue, the mains downlighters are probably GU10's which send most of their heat out the front (direction of light) as opposed to the GZ10 halogens which get really hot out the back. That said you MUST maintain the adequate space around them as stated in the manufacturers install guide.
They do sound a bit close together from an asthetical point of view mind, would be overkill IMO if you're trying to fit them in a shower cubicle sized space for example.
