Quote:
How is the shower working now for you not to be happy with it ???
It is working, but I am not happy with the performance.
Quote:
Is the pump still in line?
No, because it is now mains pressure.
Quote:
Where is it connected into the existing system?
Everything is in the loft, connections for shower are close to origin from hot tank. As I said, I am more than happy with pressure for everything else.
Quote:
Was it explained to you beforehand that the shower would not or might not work after the cylinder was fitted?
No
Quote:
What does your plumber propose to do as a way round it that costs £500?
Don't know. I have not pursued this as I am very reticent to spend another £500 just for the shower.
Quote:
Has the installation been registered with the local authority and benchmark booklet filled in?
Again, don't know, he is back on wednesday to finish off, so I can get my wife to check this.
When I said ' going through the new cylinder, into the old then back to the boiler' I meant the cylinder heating circuit only, not supply, I would keep the actual supply for the shower separate with a tank, (my reasoning behind this is that we still have the old cylinder and tank). But if this is not possible, then I guess using the immersion heater would be OK
No
