Making your own door linings
1 Oct 2010
Sussex
I have been renovating my 1880's home since we bought the property in November last year and the next job I want to tackle is replacing the tired door linings and fitting new doors.
As you can appreciate none of the openings are standard sizes so I intend to install new door linings to suit standard doors 2'3"/2'6" etc. The main reason why I cannot use door lining sets is all the walls are different thicknesses ranging from 200mm to 108mm.
I intend to buy door lining timber in straight lengths and make them up to the sizes required. Can someone advise me on the best way to do this and the steps I should follow to ensure a job?
Thanks.
Well personally i'd buy a cheapish table saw to rip down the lengths of timber to your req'd width as like you say all are different, then i'd buy a sliding mitre saw, i'd use this to to form the joint in the head of each lining. You would do this by setting the depth stop on the saw to only cut halfway through your timber then make multiple passes to form a wide groove the thickness of the sides (jambs)
A slider will also come in very handy if your doing your skirtings too and will save you time and headaches in the long run
Thanks.
Wouldn't it be at least as easy to cut the doors fit the linings?
Cheers
Richard
