Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hello all I want to put a 55 inch Tv onto a block wall that's been dot n dabbed,I read somewhere that masonary screws may be the answer but is this the case as they won't need raw plugs,but will it look crap on the plasterboard?
And easily removable if the need ever arises.
A T30 driver tip is all that's needed for installation and appropriate drill bit.
They also supply decorative caps to help the aesthetics.
These have easily 10 times greater holding power than sleeved anchors.
If your block work is common 3.6N/mm² - 7.3N/mm² then 70mm penetration will be fine.
Sleeved anchors and expansive bolts are for dinosaurs imo.
Modern TV's are not what they used to be. Some old TV's would have needed an acrow prop under them to give support.
With large tv I remove plasterboard under mounting plate [use as a template] and replace with ply to match the depth of the plasterboard, secure to blockwork then you can use ordinary screws to timber plate.
Cut plasterboard 10 mm in from edge of mount then it can't be seen .
