mazda 323f 1996 corroded fuel pipe
10 Dec 2005
Suffolk
hi there the metal fuel pipe thats runs under my car is badly corroded ,whats best thing to replace it with?. would i be able to buy a replacement part from mazda?.i have read about using copper ? if this is correct what size? where can you but it from?.
thanks paul
Yes copper would be easier to bend into place and wont corrode.
Get it in any good motor factors in a roll or they may even cut you a piece its not expensive. It probably will need the car on a lift or over a work pit as the pipe will have to be clipped into place for safety.
Main dealer part will be more expensive and you will have to check availability.
