Mazda 6 electric windows fault
  • Thread starter Thread starter ringy1
  • Start date Start date
R
ringy1
My Mazda 6 electric windows all work fine when let up or down independently but when i try to let down or up the windows by using the control on the drivers side it does not operate any of the other windows bar the driver one. Any help on what the problem is. Thanks
I get this occasionally on my Mazda 6 but usually on only one window at a time. A reset normally fixes it. Here's how.
1. Turn the ignition switch to the ON position.
2. Make sure that the power window ‘lock’ switch located on the driver's door is not depressed.
3. Press the switch mounted on one of the rear doors and fully open the window.
4. Pull up the switch to fully close the power window and continue holding the switch for about 2 seconds after the window is fully closed.
5. Repeat steps 3-4 for the other rear door and front passenger door switches.
They should now work normally.
Hope this helps.
