Hi, having a problem with MCB tripping for lights in a two bed flat. Would appreciate any help.
Problem started before xmas. MCB tips sometimes if either light is switched on. Time can vary from few mins to 30 mins but can even trip before I've a chance to turn either light on i.e. seconds after resetting MCB switch.
Had an electrian round to look at wiring of both light fittings and both tested fine with multimeter- MCB wouldn't trip when he was around. Wiring looked fine also.
Came back after xmas and had left heating on by mistake for 5 days (nice gas bill due!). Lights worked fine for a few days.
MCB back tripping again as before. Upstairs neighbours came back last night from xmas hols and problem started again today.
There was a previous problem over a year ago where they'd a leak in shower which is above one bedroom. Left water marks on our ceiling.
Is this a coincidence? I don't see any new water damage but if they used shower this morning could this be the problem?
Could the excessive heat have resolved problem while they were away?
One other coincidence was one socket never worked in bedroom and about same time as first time MCB tripped this socket started to work again. This socket still works.
I've tried turning switches on this socket off and all other sockets off but MCB for lights still tripping.
Could there be a faulty wire connection in this scoket causing a short circuit? All scokets on a different circuit.
Apologies for long winded post and I'm guessing I'll need an electrcian back out but any suggestions or comments would be really appreciated.
Thank you,
Joe
Thank you,
Joe
