McCulloch Chainsaw
10 Dec 2008
Jersey Marine
I have a I have a McCulloch 360T 2 stroke (also sold as Husqvarna )
Been doing some servicing .... went to remove main fuel line and when I pulled the line off the fuel filter - found it had a metal mesh liner .. which then stretched .... so need to replace the line.
The pn 580727101 shows as clear PVC pipes.
https://www.amazon.com/Husqvarna-Fuel-Line-Part-580727101/dp/B00TD4BY5Y
Do I need to fit reinforced, and if so where can I find one.
No need to fit reinforced tubing, unless its likely to kink!
Tygon is the material of choice, usually yellow, and the outside diameter must be matched to the original.
Can't you just clip off the reinforced spiral that's pulled out, and reconnect?
John :)
