Hi, I want to purchase a few of the MDF fake tongue and groove (bead and butt) wallboards to fit into my bathroom. Darned if I can find a retail supplier. Any leads please would be appreciated.
Apparently BQ do stock this material so I'm off to Ipswich for a look. If I can push my luck further Jason, I read somewhere that the boarding can be glued onto the wall? Could I use an adhesive to glue it direct to the existing (strongly bonded) ceremic tiles and what adhesive would you recommend?
Thank you for all your help thus far.
David.
I would suggest a few screws top & bottom to keep it in place(can be hidden by skirting and top moulding) and then something like solvent free gripfill as this has a slightly longer open time.
There is a risk of the boards cupping as paint is applied to the front faces so the screws just give that bit more security, The boarding in this kitchen was done that way although I did machine the grooves myself.
