- Joined
- 31 May 2007
- Messages
- 369
- Reaction score
- 0
- Country
Hi guys
Im planning to hook up a new outside garden tap at the other end of the garden, I presume 500mm below ground should be fine but i am not sure on what pipe to choose.
Should I use copper or mdpe? its not a very long run, only 10-15 meters.
Also if I use copper should i insulate it or not worry.
I plan just to tee off the existing garden house so if you suggest mdpe I will just run a small length of copper as the existing is copper then join this onto the mdpe.
cheers
cheers
