Hi All
So I'm thinking about installing a Megaflo cylinder - I will be getting some plumbers around to quote but have been researching the requirements.
Just needs some advice before I waste plumbers times getting around for quotes.
I will need a 210l megaflow cylinder - 4 bed hse with 1 bathroom, 1 en suite and one downstairs loo.
My water comes in the house in a blue pipe then reduces at the stopcock to 15mm.
I have a water softener and this is plumbed in with 22mm full bore valves.
I have tested my flow rate at the garden tap and i'm getting 20L per minute out of it.
My boiler is a heat only Vaillant 418 heat only boiler.
Is my flow and set up suitable or am I right on the fringes of the megaflow not working well if I go for one?
Thanks in advance
Thanks in advance
