Megaflo System Problems
22 Feb 2010
Suffolk
I have leak with my water / central heating system. It's 3 years old now in a new build flat.
The leak is coming from something called the Cold Water Combination Valve. It's a very slow drip at the moment.
The system has a Megaflo CL145 unvented cylinder and above that is a varem expansion tank.
The pressure gauge connected to the varem is reading ok for PSI but 0 for bar.
I've tried regenerating the airgap in the system a couple of times but its not helped. I think the 0 bar reading is my problem.
Water pressure seems fine and I have hot / cold water as well as heating.
Hear an occasional loud bang when running the hot water not often though.
Photos attached of the system here:
http://www.diynot.com/network/bungledoe/albums/
Can anyone help me??
Bungle
I'm no expert but I had a pair of Megaflows in our last house, and I would guess that your system needs re-filling. I used to fill mine to a pressure of 1 bar when the system was cold. Be careful not to over pressurise or you may unseat the PRV which could then start to drip.
Then shut off your cold feed, open the nearest hot tap to to the tank and regenerate the air gap. When it stops gurgling and the hot tap stops running, close the vent valve and open the cold feed. Always worked for me!
Hi, thanks a lot for replying.
Yes I think I need to repressurise.
However am I safe to do this?
Do you know how I go about doing that? I have a metal hose coming off the expansion tank.
I may get a plumber but need to know if its a 5 minute job or not so I don't get ripped off!
In my case I simply connected my garden hose to the outside wter tap, and with the tiger loop connector on the other, I connected the tiger loop to the PRV (mine was right next to the pressure gauge, and then filled the system until the pressure gauge registered 1 bar. As I said in my answer, this was with the system cold.
Took about 2 minutes and no tools or skills required!
Ok I'll have a go thanks.
I've got a metal hose coming off the Varem tank. There's a small black switch on it.
Near that is what looks like an input pipe also with a small black switch.
I guess I need to connect the two up, open the switches and pressurise?
I live in flat so no garden hoses about here!
This makes no sense, I suspect you're looking at the red 'target cold pressure' needle and thinking this is a pressure reading, which it isn't. The black needle shows your pressure reading, if this is at 0 then it needs topping up although it is probably not connected to your leak as the leak is on the services to the taps and the pressure gauge shows central heating pressure
Although it isn't your problem, think about what you're saying here. You think that you have a leak with a zero pressure reading? Do you really think that increasing pressure is going to make the leak go away? As it happens it's a leak on a different system so that's actually irrelevant, but always good to try to encourage some logical thinking IMHO
Bungle
Could you post some clearer closeup pictures of the leak please. Your pictures are very dark and hard to decipher, and also of the wrong bit of the system in some cases.
a. First off there's already a filling loop (correctly disconnected after filling the system)
b. Secondly, you don't go faffing about with garden hoses if the install was done correctly
c. The pressure is zero, the red finger is just a set point
d. You need a G3 qualified Plumber, someone who knows what the hell they're doing!
Ok thanks.
I'll try and find a G3 plumber in the Ipswich area.
The leak is coming from the Cold Water Combination valve at the top, which I believe is the PRV cartrdige apparently.
I'm not going to fill up the system in case it makes it worse.
I'll get someone in ASAP.
Thanks to all.
