Megaflow Cylinder
8 Nov 2009
Manchester
I seemed to have lost pressure in my hot water so that it is merely a trickle. I have a mega flow cylinder and the problem happened suddenly and I have no idea why.
Cheers in advance for any help
Tommy
Is your cold tap in the kitchen ok?
Kev; how would the air gap affect the flow at taps?
I reckon if you unscrew the filter on the end of the spout and clean it, it will be fine.
Either that or someones turned the cold water off.
op said:
Cheers for that it just needed the air gap reinstating!!!
Don't set ya funny emoticons on me !!!! :evil:
I was actually asking if it could solve the problem, and if so how.
PS I don't believe it solved it.
The pressure appears to be holding. It did take a good twenty five minutes to reinstate the air gap by holding the valve open. I know nothing about plumbing but on this mega flow cylinder as i understand it, the cold water comes off the mains into the bottom of the cylinder, and that is used to push the hot water round the system. So i don't know why that has fixed it!
