MegaFlow Problems
10 Aug 2009
London
I have recently bought a house with a MegaFlow boiler. The problem is that it gives boiling hot water for about 10 minutes and then it stops and runs cold. If you wait about 2-3 hours the same cycle happens again - ie. hot and then cold.
Any ideas about what the problem could be? Anything that I can do myself to figure the problem out / fix it?
Many thanks,
Sam
What's a Megaflow boiler look like asI've never heard of one.
Do you mean a cylinder.
How is it heated.
No John, its actually a boiler!
Since they bought the brand name they have to make the most of it.
They are pretty new in the market place and if you have the right documentation then its probably still under the warrantee.
Otherwise you will have to call an independent but make sure you call someone who knows its a boiler as the name is best known for a cylinder!
