Megal flo discharge query
7 Jan 2007
London
hi all, i wanted to know if anyone knows where i can buy the high temperature resistant (101 degrees +) plastic pipe for the d2 pipework .
It's called M-UPVC, and they'll charge you through the nose for it so I hope your megaflo is close to the stack if that's where you're running it to
it is also called pushfit plastic waste pipe. get it from screwfix or b&q
thanks guys, phoned hep and they advised me on the plastic pushfit pipe, but doubted that ill find a stockist in london as the solvent weld pipes and fittings apparently get used more in london.but i will try screwfix seeing as pts have to order it in
