MENVIER TS700
14 Apr 2010
Hi I have a Menvier TS700 Lb is showing on the keypad, low battery, does anyone know if I need to enter the code I use to enter and leave my house before I remove the lid from the control box.
Also if someone has step by step instructions that would be great.
if you take the lid off the panel, the alarm would go off, entering your code will silence the alarm.
Depending on how it was programmed, you may need an "engineer" to reset the system. This can be overrided by defaulting the panel but then you will lose all of your settings.
