Metal Back Box Clips
That’s a smart application bringing on the extraction
I must remember that , one bringing on the other . Im used to thinking the other way round with 1 appliance disabling the other
as pictured it is 1 appliance disabling the other, as mentioned I added a contactor (Not easy due to the bulk of the hours run meter filling the space) to bring on the second appliance. It's one of those 'projects' born out of necessity which I was telling myself while converting it that next time I have to add a switch to make it an instant conversion but also thinking it should be a different enclosure and sockets mounted into it rather than just a brass bush and... and... then thought what the heck it's only a handful of bits of junk.
Well, after a very long drawn out affair, we have had the HSL decorated and I've finally got round to the second fix.
Here's the socket in the hall I took an unfused spur off which I fed through the wall (where the 20A connection plate is) to the socket on the other side in the dining room.
The dining room
In our en-suite (done much later), we have a towel rail heating element with built in controls. But this is for the bathroom, for which I got this separate stat.
It's annoying me that the Dimplex plate stands out like a sore thumb. I have spare MK dimmer plate somewhere that I may well get engraved to match and swap them over.
I'm most proud of these two, but you can't see the work that went into them! This Paramount wall was a right royal mess, cracked up and broken where two single boxes were fitted above and a double and single below. But I fixed and reinforced it with plasterboard, then filled and sanded. Bonding and Toupret are amazing! You'd never know, and it's a really sturdy fix.
The final 35mm box screwed into wood. In this case, the wood is mostly glued to the reverse side of the wall with "Sticks Like Sh*t", then screwed to the vertical stud on the RHS with very long screws.
Do you really need the engraved 'Off, min-7' scale?
If not, why not a 4-module Euro front plate, fuse module, switch module, 2-mod blanking plate which you drill and mount the Dimplex control? (I'm assuming here that the whole thing is held onto the plate by a nut around the thread of the potentiometer).
