metal roof on ply with membrane
22 Sep 2015
hi im not to bad at certain building projects but metal or corregatted bitumen is still a bit puzzleing as im about to do my garage,
im going to lay a base of 20mm ply and lay a damp proof membrane on top
do i just screw the sheeting to the ply through the membrane or somthing else? or any beter ideas,
if i screw through the membrane wont it leak?
might just be being stupid thanks in advance
If you are going to use box profile metal sheets then you can buy anti condensation sheets,
Fit 25x38mm tanalised tile battens above the membrane (running down the roof) and fix the roof sheets to these. Don't fix directly to the membrane, else this will wear as the sheets move naturally.
There won't be any significant water getting under the sheets and the membrane won't leak (shouldn't leak) by fixing through it.
