Were as the rest of the rads are on solid walls I have dropped 10mm so can be plaster over. This ok?Have done similar to that,I have done similar to the above.have used duct tape for corrosion protection. Though one downstairs rad is on a studwall I have dropped in 15mm and reduced to 10mm on the elbow as it exits the stud wall. Have done this to give the pipes more stability. Should this be ok?
