hello guys and girls, got a question for you. where is normally the manifold postioned on a microbore system?? i can't see it near the cylinder in the airing cupboard.
You may have a couple one on each floor feeding the rads.
Follow the pipes from the boiler they are usually under floorboards with an access panel positioned equidistant to the rads.
Pete
no its quite old, i'm putting in a en suite so they want the old rad piped up in microbore taking out and a towel rail putting in. can i just connect onto the microbore will i have to take it out and repipe in 15mm??
Pete
