I've had a quick look on the forum but nothing seems identical to what I'm experiencing so I thought I'd have a quick ask to see if anyone can help!
I have a Micron 30FF combi boiler that heats the hot water (stored in an insulated tank in the house) and also heats the CH system. The problem is that it no longer sees a demand for the CH even with the thermostat turned up to 30 degrees and the LED on the programmer on to indicate CH demand.
The HW demand is fine and works without issues. The thermostat audibly clicks at around 18 degrees.
Could this be the thermostat or the programmer? Is there any way I can trick the thermostat to output a demand by joining up a couple of the wires?
As an aside: when the HW turns on the radiators also heat up. I presume this is a by-product of the design of the system but it's a bit annoying in the middle of summer - although useful now as it's the only way to heat the house!
Dave
Dave
