Hi, I've just about read every diverter valve thread on here now as at one point I thought that was my issue but now I'm not too sure.
Any advice?
Have conventional Y set up with Drayton Flowshare2 diverter, ASL electronic programmer and stats all heated by Gloworn Ultimate boiler.
For few months had some ticking noises from airing cupboard and having read about this thought might be air in system. Continually bled all rads and opened air vents either side of pump on regular basis which let out only a little air each time. So thought maybe pump on way out and would soon have to replace.
Last week have had issues with boiler igniting, programmer all lit on LEDS and pump running but no heat to CH.
Then having tried switching on and off (very technical) noticed that boiler lit when only selecting HW, then selected CH too and rads heated. But then when HW reached temp to satisfy cylinder stat and the the whole lot turned off.
At this point thought was 3-port valve having read loads on here. Found operating instructions for valve and did tests (i.e. both stats high then CH low valve moves to HW reverse and valve moves to CH) and it appears to be moving as it should???
But now boiler not lighting at all even when just HW in demand, pump continues to run so I am confused as cannot find in any threads whether pump should still be running? Test pump speeds andsound to run ok at all 3 speeds (Wilo Gold 50)
So my thoughts are microswitch in diverter valve - so do I replace whole thing??
But would pump still be running if microswitch was at fault??
Can I replace with Hortmann using nuts and olives on existing pipework, are these all standard?
Thanks for any help.
Any advice?
