Mildew in kitchen cupboards
20 Sep 2006
London
I have got mildew spreading inside the kitchen base units that run along an outside wall (the ones on inner walls are OK).
I had damp proofing work carried out when I moved in to the house 7 months ago and fitted the cupboards about 2 months later. Could the mildew be occuring because I didn't leave the wall exposed long enough to dry out? Will it dry out? Could it be anything else causing it? :?
Depressed and worried :cry: - I have just finished the kitchen and don't want to have to rip all the units out! Help!
Is it near the dishwasher, washing machine or sink :?: Is the back wall damp :?:
condensation :idea: .....kill the mould with a bleach solution....leave cupds open if poss to allow walls to dry
Thanks guys.
Yes the sink and a dishwasher are in the middle of the units. Not sure if wall is damp because it's behind the fitted units. The exposed bits aren't damp and it was brand new damp proofing. I took the plinth off and had a look at the exposed bit under the units. It has a few black spots but doesn't feel wet or look damp. Smells a bit damp though.
Any more thoughts???
As Nigel pointed out, it's most likely to be condensation, could be the heat moistures from the dishwasher or there's a leak from the sink area.
Either clean more often or ventilate more to keep the area dry.
Is the outside wall in good condition?
The rendering on the outside wall is flaky, but it was like that when we bought the house last year before we had the damp proofing done and it hasn't got any worse. The outside wall is otherwise in good condition. No cracks, no damp patches. :?
