Hi there,
I have a property where there appears to be a build up of mildew on the inside plastered and painted walls, the walls are being wiped down, however these marks come back over time. The first image is in the outside corner of a bedroom with single rad and to small windows and one large window. There is an air brick installed.
The wall is solid stone - no cavity.
In the second image, this shows the mildew on a joining wall with next door, this is not on an external wall.
Lastly is the outside front (which is brick) that has the following on the inside:
the rear elevation has been re-pointed and it seemed to be better with the previous tennants in the house, there seems to be a lot more build up of damp/condensation/mildew in the house since the new tenants moved in. Does anyone have any advice they could give please as I don't wan to just paint over whats there, I would like to sort the issue out......
Any help is most appreciated guys.
Andy
Andy
