- Joined
- 16 Mar 2007
- Messages
- 41
- Reaction score
- 1
- Country
We have a microbore central heating system. The rad in downstairs cloakroom is 6mm dia pipes. The plumbers said they cannot get 6mm fittings so have fitted a new rad (the old one was rusty) and then cut off the 6mm pipes at floor level (as no longer used). The plumbers have put in a new pipe run (approx 15mm dia pipes) one to each end of the new rad. They have also fitted a Thermostatic valve. The problem is that now the pipes make a terrible noise every night, we thinks it is caused by vibration even tho' they are clipped to the wall. Sometimes it stops when we turn the thermo vale up or down, but last night the only way we could stop the noise was to turn the central heating thermostat down in the hall, so the boiler went off.
I guess it may be a pipe size/flow problem, but ANY help would be greatly appreciated. Its a great forum.
I will speak to the plumbers, but I would like to be in a position to know what I am talking about (if you get my drift.
Hope you can help. Regards.
