minimum bearings on spreader plate
5 Mar 2011
Sussex
Hello
First post for a while but long time reader (reregistered)
Looking for some advice regarding my loft conversion please.
Am just installing spreader plates in my loft gable end walls to support the beams. The engineer has specified 250 x 100mm wide spreader plates which I have.
On cutting into the walls what should have been a 100mm thick block is only 75mm. It appears the brickies have change from 100mm to 75mm at ceiling level.
Now I'm thinking I could just change the lower blocks under the bearing to 100mm, but what about the ridge beam? Do I need to build a pier up to the proposed steel and ruin my nice flush wall line?
The ridge steels are 152 x 152 x 23 and the maximum span of the two (post in the middle) is 3.8 meters
I will run this past BCO on Monday, but was wondering if anyone has experienced this before and has a solution to discuss with the BCO.
Archroy
Tell the engineer who designed the beam about the reduced wall width, they will be able to advise if a different sized spread plate is required or if the original size is adequate..
Many thanks, Static
I contacted the SE and he said all was fine, just need an increase in pad size to keep the bearing area the same.
Archroy
