minimum pressure tap
20 Aug 2007
Manchester
Hi I am looking for bath valves but don't know which pressure to go for. I have a hot water storage tank in the airing cupboard and a cold water header in the loft. the bath hot water if fed by a 22mm pipe with the last 2 ft 15mm and a flexible hose to the tap. Would a bath valve rated for 0.5 bar minimum provide a good flow for the hot water?
thankyou
Hi there,
I think youre going to problems. Are you sure you have the right taps for your bath.
Bath taps usually come with 3/4inch threads and you feeds should be 22mm all the way to tap.
Rico
