Mira Advance Electric Shower intermitent fault Thermostatic
11 Feb 2007
Cumbria
Hi
I would be greatful of our some help my mira advance 9.8kw shower has operated faultless for a number of years - it has now developed a number of intermitent faults
It flashes up a red light - service required - then runs cold - some times if it is switched off it will restart
other times its clicks and then stops - Is this a solenoid issue? other time it will not switch off with the panel button so we need to switch it off with the isolation pull cord
any help would be greatfully accepted
Thanks in advance
sounds like your relay board is up the spout.
most common fault on the advance.
retail about £70
