mira event xs thermostatic power shower problem
you guesed wrong denso
Apologies, you're right, quick search gives much more than that :). What problems are you having, might be an easy fix?
*Edit* Just saw your other post
been told the inlet filters may need cleaning?? turned of the water but the shower still runs both hot and cold as i know sod all about plumbing, stumped at the fist hurdel or is that the pump draining the tank????? the pipe work is like a maze
