Mira Flight Low Rectangular Shower Tray - any good?
4 Jan 2012
Hi guys
Ive found some slightly older threads about these trays but can anyone enlighten me whether these are any good or suggest something simular please? Looking for a low'ish 40mm or so profile shower tray. Have read the main thing is the fitting/bedding for them as they can crack.
Yes, excellent trays, I've fitted loads without any issues
Would you install with the riser kit (or does that just depend on if you need the height?) As we have space under the boards to run the waste.
Also any tips for fitting - best base to sit it on as we have 22mm ply currently.
Assuming you can get the waste out without shredding the joists sat on the 22mm ply will be fine
Conversely I've seen a number of damaged flight trays (mostly de laminated) But we .were sub contractors to a large specialist insurance contractor.
Tended to see the bad and ugly side of the business.
So you wouldnt belt and braise it with a sheet of wsb?
