Mira Zest cutting out
19 Mar 2011
Gloucestershire
I have a Mira Zest electric shower - about 4 years old - and it has just started to cut out after about 5 minutes of use.
I've checked the wiring connections and nothing is burned out.
I've checked the inlet filter which is fine.
I'm not running the shower excessively hot - i have the same problem running it at luke warm.
I've checked the shower head which isn't blocked (we don't have a big limescale problem).
It's not tripping the fuse.
The water pressure is fine.
Any suggestions? I know this topic is well covered on the forum, but i'm pretty sure that i've tried everything that's been recommended so far.
cutout as in what heat, just the water flow, or complete power failure ?
i would say you mean just water flow.
if so the solenoid coils faulty. check the resistance on it in its failed state.
as for the tco faulty they will only stop the water heating. not cause a flow fault.
