Mixer shower won't mix
21 Dec 2004
Hello,
I've just bought a flat and the mixer shower attachment which comes out of the bath taps, will either give cold or boiling hot water, but not both. If I turn the hot tap on first, the water will stay hot even if I turn the cold on full.
The same is for the cold tap - if I turn the cold tap on first, it will stay cold even if I put the hot tap on full.
The flat has a combi boiler.
Any advice eg will replacing the mixer work; what model etc will be appreciated.
I'm totally new to the world of plumbing, so don't worry about stating what you might think is obvious!
Chris
Give the Shower Dr a ring and they will advise you if your mixer is serviceable. They are helpful and do mail order. :)
0121 707 9240
