Looking for some help with a mixer tap which looks very similar to this:
Basically, the handles have loosened so that when you try and shut the water off, they are up against the wall tiles behind The Handles themselves can be unscrewed which then allows the whole knob to be spun 360. Doing this, I can put them back into the desired position, however if they are pushed to hard on closing, they end up against the wall again. This can be remedied by opening them fully and then pulling the handle around a little bit more.
Is there a way of mixing the closed position permanently?
Can the 'cap' be popped off? Is there anything underneath that can be tightened up?
Cheers.
Cheers.
