Mixer tap with tmv hardly any hot water flow
16 Jul 2009
Hull
What issues could be causing little I mean very little water flow from a mixer tap on the hot side that was a tmv fitted to the supply. Cold side flow rate is good. Mixer valve check valve fault? Filter in the mixer hot side block. The tap is a lever tap I presume the problem. Is with the tmv. Thank
Trace it back to the valve, disconnect the hot feed and test it, then the mixed output and then see how that flows ..... process of elimination
Thanks what can stop the flow or reduce the flow massively on the hot side. Of a mono block basin mixer tap? And or tmv2. The water is getting hot just the flow is minimal on the hot side. Thanks.
Do tmv2s work well when feeding a mono block mixer valve? As the water already mixes in the tap.
